Discuss Downlight advice - joists / spacing guide in the Lighting Forum area at ElectriciansForums.net
What are people's methods of installing downlights?? Rule of thumbs?? Spacing?? I installed 14 today in a kitchen. 2 banks of 7 at just over a metre apart. 650mm from walls. Problem is joists. felt like it took an eternity just to mark out as I would inevitably land on joists somewhere along my row then knocking out measurements. I didn't want to start pushing some 50mm forwards or backwards as wanted them all equal. I managed it but had to keep amending accordingly. Any advice on speeding things up appreciated!!!
It was a open plan kitchen/diner but the customer is serious OCD and insisted he wanted them all evenly spaced as 2 rows. 2g switch 10 and 4. I used a laser to ensure straight but marking between lights was a nightmare.
Yea it's a nightmare, sometimes it works out sometimes it doesn't!
Hopefully your next one is easier - You will get quicker !
I had one recently where they had a massive roof lantern so all the surrounding timberwork was double or even tripled up, there was more wood than space to put lights took me forever to lay out!
I prefer a chalk line, only use a laser when the ceiling is painted also need a good quality tape that doesn't keep bending - fatmax XL for me!
Joists are generally 400mm or 6oomm apart. Your 1st row was 650mm from the wall and a meter apart. 650, 1650, 2650, 3650, 4650,5650,6650 So if they were 400mm centres you would hit 3 joists out of 7 lights.
I dont think there is a way to speed it up... The joists may not be equally spaced, or not a 'standard' distance apart. You can only check, measure, check again.... Sketch a plan, see what it looks like..
Watch out for wood crossing the space between the joists too!
Perhaps I'm looking into it too much. Just took forever just to get set measurements to miss joists consistently. I suppose give or take 50mm when landing on a joist isn't the end of the world. Just nice to get everything evenly spaced.
1100mm apart...That's really surprising. I've never seen joists that far apart before. I can't see how at them distances how it would be structurally sound and must of been a complete ball ache to board as sheets come in 2400mmx1200mm size so when the joists are laid out in either 400mm or 600mm centres then the board finishes on the centre of a joist.
Apologies mate. The downlights were spaced at 1100mm.
After marking out where they go,I drill a small hole enough for a coat hanger wire,I bend the wire at 90% angles to exceed the width and depth of the downlight
Insert it into the hole and do a full twist,hopefully there should be nothing restricting the wire,then drill the hole with confidence
There is nothing worse than the apprehension of cutting a sizeable hole and ending up meeting some restriction
With the best will in the world,there is always the chance of a doubled up or out of sequence joist...or one that is thicker...or a spurious noggin.
If the customer wants exact and equidistant setting out,on a retro fit job,allowances for time and cost,must be accepted.
Another little snag,is precise and orderly setting out of one's own components,can then show up another's foibles...yes,i'm talking to a tiler and a kitchen fitter i have in mind...;)
Reply to Downlight advice - joists / spacing guide in the Lighting Forum area at ElectriciansForums.net
Hi! I was hoping someone could give me some advice on how should I space the downlights on the landing area. I’ve read it’s meant to be 1...
Hi all. Long time lurker, first time poster. I am not an electrician but I enjoy learning as much as I can. I am currently renovating a house...
The Ghost
T
Morning chaps Finally doing my 1st intake on the 19th! It is for 14x flats and 1x L/L supply SSEN are installing the new incoming supply and...
Toneyz
T
H
For the past 2 years or so I've felt like a change in career, and becoming an electrician has always been top of the list. Anyhow, I'm 30 so need...
hightower
H
M
First of all I would like to thank you for the sticky on Child Plug sockets. Will be sure to pass this info around. I had an idea to fit accent...
mik_dundee
M
