Discuss Downlight spacing calculator in the UK Electrical Forum area at ElectriciansForums.net
Could be useful. the interesting thing is that the calculator gives no method of ceiling height.
IIRC the amount of light that arrives at floor level reduces with distance, so that must mean that more lights are needed for high ceilings.
Usually governed by trying to get a symmetrical spacing that fits with ceiling joists.
Obviously you get more technical when considering ceiling height, lumens and beam angles.
who had the common sense to stick to feet/inches/yards/gallons when the UK was obsessed with euoro phile rubbish.
Of course the maths side of things works best when you got straight and flat walls. Seemingly a rarity. Otherwise what is mathematically accurate and spaced out well wont necessarily look aesthetically pleasing or accurate. you also have to factor the joists in to the marking out.
I have some thin MDF discs that i put some old chrome bezels on. when i am happy with the marking out, i stick these up with some little screws or double sided pads.
If I am happy then great, but I often get the customer to decide, and often move a few a couple of inches one way or another along the x or y axis, to get the visual effect
Reply to Downlight spacing calculator in the UK Electrical Forum area at ElectriciansForums.net
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
So I’m an apprentice and only get to do downlighter jobs as foreigners at the weekend, but they’re typically added when the customer no longer...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Hi guys, super basic question: For a room layout like this, with my understanding that a lighting circuit downlight radial goes from one point to...
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
