Discuss Downstream db in the UK Electrical Forum area at ElectriciansForums.net
Iona222
Trainee
I've got my 2391-52, but I've never tested a board downstream, its a db for an extension, there's no rcd on 1 lighting and 1 ring.
Is it ok just to change the mcb to a rcbo.
I remember wheni did the course they mentioned selectivity/discrimination
Regards
The main switch on the board is a rcd switch.
Don't know which board you mean has rcd main switch, but surely in either case that means the lighting circuit and rfc are RCD protected after all?
Stick a photo of each board up if there is still confusion.
The main board has a rcd switch. Ye so I would say, they are protected.
Reply to Downstream db in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
Hi, I have been tasked with a kitchen rewire. The current DB is fed by a 16mm armoured. There is a split load old contactum DB which I don’t...
Hi there, long time lurker, first time poster here. Straight down to it.. A friend asked me to add some sockets and additional lights to a small...
Hi all, been reading around this and i have to admit ive quickly gone out of my depth as regards EV chargers. The charger in question is a...
Big argument with a newly qualified electrician with all the necessary qualifications Had to give him a hand later on during the day, nice DB...
