G
graham123
Using a single phase db, how do you install double pole mcbs into this to use as a 110v db? Does the busbar need altering? As how do you get the neutral side onto them?
Discuss Dp mcbs 110v in the UK Electrical Forum area at ElectriciansForums.net
Eh? DP MCBs? @110v on a bog standard CU?Using a single phase db, how do you install double pole mcbs into this to use as a 110v db? Does the busbar need altering? As how do you get the neutral side onto them?
Reply to Dp mcbs 110v in the UK Electrical Forum area at ElectriciansForums.net
