Discuss Drain on battery in the Auto Electrician Forum area at ElectriciansForums.net
I have a Renault Megan Authentique 1.4 petrol 52 reg. it is used Mon-Thurs for work. I find that come Mon mornings the
battery seems flat & wont start unless I use a jump start. I have changed the battery but to no avail. I am told there is a leak or load on the battery which runs down over 3 - 4 days. Any ideas what to look for or test. I am a domestic sparks
interior light/s staying on? all modern cars have some drain when left standing. can you not give it a run on saturdays?
Check the tension of the alternator belt and its output. Check as Tel says for lights staying on , possibly in the "boot" area. If the alternator is OK use your clamp meter at the battery after the car has stood awhile and check to see if there is excessive current draw . One amp for instance will drain the battery in relation to its amp hour rating, but will be quicker if it is not fully charged in the first place. If you are running A/C and other heavy loads the length of your run may not be sufficient to keep your battery fully charged.
As ruston says use a clamp meter to check everything has shut down - apparently on French cars that can take a while because there's a lot of electronics involved.
I was told that by an RAC man.
Do you have an antistatic strap fitted, the thing that trails along the ground as you move, my mate had one that for some reason would discharge the battery on wet grass overnight on sites, at home on the drive it was ok.
Pict
How to test your battery drain.
Disconnect your battery, set your multi meter to 10ADC then place it in series between battery and lead, IE negative lead from multi meter on battery and positive lead of multi meter onto battery lead, look at the reading, it should be 0.0 something, if higher, pull your fuses one at a time until you find what is draining your battery.
When doing the test, make sure that interior light is switched off, and any other elecrical device, IE radio etc...
I hope this makes sense and helps too...
Reply to Drain on battery in the Auto Electrician Forum area at ElectriciansForums.net
Hi, I have these Omron BF511 scales which notoriously develop a battery drain problem. Normally they are supposed to last a year but suddenly they...
I bought a used golf cart a few days ago which had their batteries replaced last year. They hooked up an am/fm radio to it and it worked fine when...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
Hi, My Peugeot Boxer 2.0L (X reg 2000) petrol based campervan has developed a problem. We were away last weekend and when I tried to start the...
Hi Folks, Got a bit of a mystery on my hands and it's so far left 2 RAC techs and a local garage absolutely baffled. 10 Days ago I bought a used...
