Discuss dscrepency between notrp and hi in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
crabapple
ive noticed when doing loop tests, there s a slight diiference between notrp(i think its 15 ma) and hi which sends out about 20a
is it just me??
No mate it's a common occurrence.
In lab conditions both No-Trip and Hi loop test measurements are likely to be similar, certainly within the accuracy of the MFT, but add in the oxidized joints of a typical real world installation and result is likely to be completely different. My money is on the Hi current loop test giving the more accurate result because the higher current is likely to be able to break down the oxide or tarnish film.
The old robin loop tester I have will give you textbook readings when testing an old install! My megger on de-lock is will regularly give readings of 0.8 on a socket where the robin will give you 0.3!
Usually if you push the plug in and out a few times readings improve.
Reply to dscrepency between notrp and hi in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi Guys After bit of advice please as we don't do much data normally, tend to sub it out. Had garden building this week which we'd run in SWA...
Long standing issue on my VW Transporter T4. First noticed under 'lockdown'. Battery drains flat if stood more that 3 - 4 days. Industrial spark's...
I saw a Fluke 1653B on Gumtree local to me being sold as faulty. Fault was stated as no continuity between 'N' and 'PE' ports on the resistance...
Hi question whats my best route ive just done the am2 and past my nvq has expired as i took a while before completing the am2 i have level 2...
Hi all, Gone to look at a intermittent ground floor sockets fault today, the RCBO was tripping at random times with no pattern. Nailed down a...
