Discuss Dual consumer unit and meter move in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone,
This is my first post.
I live in a semi detached timber frame type house. I am taking down a non supporting wall/ cupboard in my sitting room which will give me an extra 1mt x 3 mt of space.
Unfortunately in the cupboard there is the electrical meter, fuse box and storage heater fuse box.
I would like to maximise the space so was thinking of fitting a new consumer unit which would have a separate main switch for the storage heater circuits. Is there such a consumer unit available, and is it possible.
I would also like to sink the consumer unit into the wall,again to maximise space. The consumer unit has to stay where it is, due to cable lengths but was thinking of getting the Scottish powers meter moved about 2 meters away and running in new tails.Is this possible.l have attached a picture of the board etc.
Any info or thoughts would be greatly appreciated.
Hello everyone,
Box it in a simpler solution
Have you have a quote, to see how much this would cost? I'd be interested to see what they quote.
You can also get a new CU fitted in a new position. This will also cost.
Hello everyone,
If it s on a wall with a cavity then you could take away the inner wall and resess the consumer unit and meter in a cupboard and put door on, don't forget the lintel. Looking at your photo would be a good idea to upgrade you consumer unit
Thanks everyone for replying.
I am going to change to a new unit if I can get one that incorporates economy 7.
Don't want to box as the want a corner sofa,so need all the space.
Not sure if it is tns or tncs, meter has been changed a few times over the years
You can get what is known as dual tariff consumer units which will incorporate both systems.
Reply to Dual consumer unit and meter move in the UK Electrical Forum area at ElectriciansForums.net
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
Consumer unit is being moved 10 meters away from outside meter cupboard which is mostly occupied by economy seven timer thing which customer don't...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
