Discuss Dual LED security PIR suggestions in the Lighting Forum area at ElectriciansForums.net
so how much pocket money have they gave you .Timeguards are a little expensive I think
Looking for a quality dual PIR security light for a friend's house. I've done some searches but they all look cheap and I don't recognize any of the brands.
Any recommendations?
I'm confused. You want a quality one, not a cheap looking one, but the quality ones are too expensive ?
Get a timeguard one, they are very good.
I didn't say the quality ones are too expensive. I just said the timeguard ones were too expensive. I'm sure there are some quality ones more within the £50 range.
You can get a timeguard twin spot PIR for £60 .... oooh, temptingly close to budget
Yeh looks like you can. Doesn't help that I was searching for the 10w only
It was the 2 x 10W I was on about. The 2 x 8W are the older model.
Timeguard LED Nighteye PIR Floodlights in White Or Black - Edwardes - https://www.edwardes.co.uk/en/categories/led-timeguard-nighteye-pir-floodlights-timeguard
Managed to convince them it's worth the extra cost. However, now they have asked if it's possible to sometimes bypass the sensor (when working on the car at night etc) and then engage the sensor again after.
If the light is fed via a SFU and the power is turned off and on, will the light bypass the PIR? And then off and on again to engage the PIR?
Reply to Dual LED security PIR suggestions in the Lighting Forum area at ElectriciansForums.net
