Discuss dual rcd consumer unit on tt earth. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
IMO 100ma Time delay was post 17th edition when you didn't need 30ma on most circuits to cover cables buried in walls, bathroom circuits etc. It provided additional protection if ZE and therefore ZS were insufficient to ensure disconnection in the prescribed time. With a Dual RCD board and all final circuits protected by 30mA I cant see a problem. The main switch will only be protecting the tails to the RCD's. What protects the DNO's tails to the DB??
The issue will come in December when we have to fit Metal DBs... What protects the metal DB... Class 2 metal DB? or do I go into business producing asbestolux enclosures for DB's :winkiss:
I was recently at NAPIT Expo. The expert panel stated that come January a TT install need only have entry into the board via a stuffing gland or similar. One of the panel even said if you can get plastic trunking, with the tails in, into the board through a knockout then no upfront 100mA required. Sloppy in my view.
It used to be that way years ago. Wylex used to make metal CU's with a special clamped entry bush and clamped connections into the main switch RCD,which meant there was no possibility at all of the tails shorting onto the case. I cant see a problem with metal CU's on a TT today (and no upfront RCD) as long as the same precautions are taken.
Problems will arise though because this approach demands a level of skill and understanding that many of todays electricians just dont possess.
Yes of course it can, what worries me is you need to ask, I am aware negative posting is not allowed and fair enough so please take this as constructive, get yourself a regs book.Am I right in saying a duel rcd(plastic at present)cu can be used on a tt system without an upfront type S rcd incommer?
Thanks for any replies,sw.
Reply to dual rcd consumer unit on tt earth. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
