- Reaction score
- 2,783
I have a domestic customer with an Economy 7 supply, where both the main supply and the off-peak supply are brought into the one fuse box, with two separate main switches in the centre. The customer wants the fuse box replacing with just one new consumer unit. The property is a small 1-bed flat, total of just 7 circuits (two are E7 – water heater, storage heater).
I typically install Wylex CUs, and Wylex do a Dual Tarrif range (prefix NHIIX, e.g. NHIIX7504 for 7+5 ways). Because these dual tarrif CUs are less commonly sold, it seems I’d pay about as much for one of these – a bare CU with just the two main switches – as I can buy a Dual RCD CU with 10 MCBs already installed.
I am thinking, can I take a standard Wylex Dual RCD 10xMCB CU and reconfigure it by removing two MCBs and adding a second main switch. I’d use one RCD for the main supply, and one RCD for the E7 supply. And since the lighting comprises two circuits, perhaps put the larger lighting circuit on a separate RCBO. The CU has 3 separate neutral bars to support this configuration.
Am I missing something, is there some reason why I can’t do this, either practically or regs-wise?
