Discuss Duraplug FC4134WHI 4 Way Portable Extension Socket. Fused. Neon. in the For Sale and Wanted Forum area at ElectriciansForums.net
Hi all
I have some unused new/boxed Duraplug FC4134WHI which I bought for a recording studio/live rooms project which ended up being a far smaller venture than I imagined! I'm now selling on those surplus to requirements.
When I looked into what extension sockets to use in my studio and house, I was told that these are far better than the surge protector type extensions. By all accounts, the only surge protectors that are effective are very expensive, unlike the ones found in DIY stores which would not actually help in the way they claim to. Quality components and build quality are far more important. These should last donkey's years too, and can handle being knocked about
Duraplug are a well known, tried and tested make, and these units have great build quality and are made using decent quality components and materials. The sockets grip the plugs far better than they do on cheaper extensions. Better contacts on the Duraplugs also result in a lower impedance to earth.
This ad is for one item, but I do have more for sale if you require more than one. Please get in touch for details. I'm sure we can work on a good price if several are bought, and I always combine postage. Happy to ship anywhere….
I'm based in Norfolk...
Cheers
*****Product Range Information*****
4 gang heavy duty, fused extension sockets
Neon indicator
White
Wall mountable (can also be bench mounted)
Material: high impact ABS/Polycarbonate
Manufactured to BS 1363
Dimensions: (LxWxD) 317Lmm x 68Wmm x 31Dmm
Reply to Duraplug FC4134WHI 4 Way Portable Extension Socket. Fused. Neon. in the For Sale and Wanted Forum area at ElectriciansForums.net
Like a host of UK residents recently (230% increase in genny sales apparently), I've just invested in a small (3500W) portable, dual fuel...
For emergency use, when there's a power outage, the current situation (no pun intended) is that I'm running a hook up cable from the 16A socket on...
I know it's not neat, but can I simply run a single extension cable from a small (3KVA) petrol, portable, inverter generator, positioned outside...
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
  • Locked
Currently I have a spur from the ring main, but I'm planning on adding more sockets. I can't add a 13 amp fuse because I expect to be using more...
5K
