- Reaction score
- 3,912
This is what your up against, keep saying its a race to the bottom especially with LL reports.How the hell can that be considered an EICR???
Discuss E.I.C.R rant by arti electrical in the UK Electrical Forum area at ElectriciansForums.net
The whole thing, testing inspecting and cert. So first thing I do is inspect CU and Cut-out, then earthing then all fittings for damage and security of fixing. Check the physical tightness of bonding clamps and labels. Then remove fittings usually starting as 25%, more if there are signs of poor wiring like no earth on metal boxes, poorly wired sockets with no earth sleeving, remove electric shower cover and switch to check for thermal damage. Then the testing. Everything unplugged, noting neons for IR testing. Do ring final circuit tests. R1/R2 on every circuit, just attach L to earth bus bar for each circuit, use the plug device for sockets for R1/R2 this also ensures continuity of cpc and polarity. If present also check function of emergency lighting, not full three hour test though. I use my ipad as I go to note all test results and this forces me to do everything as I go. Last three bed I did was 6 hours. That house had a loft ladder so easy to inspect it quickly cables flopping all over the air space in there very poor wiring.to do the tests or does that include paper work
We had a similar situation on the electric board i did my apprentiship with - despite charging roughly double what most did and justifying it "because our high standards" they then took on teams of "contractors" who turned up in rusty transits complete of course with towbars.... A callback on one of their installs revealed such delights as a pipe clamp on the water with enough 10mm attached to conveniently tuck into the ceiling and no more... Unsuprisingly the contracting side of said elec co doesnt really exist any more.We had a company subcontracted to ours to help with the testing. A few of us expressed concerns to the higher ups but their response was well they're cheap. We found their paperwork wasnt adding up and upon visiting a few properties they claimed to have done found they couldn't possibly have done them.
So now we find ourselves going back over these properties and I can't count the amount of times I'm not even half way through when a tenant says
"You're more thorough than the last one...he was only here 20 minutes"
Then there was the remedials. Observations worded "plastic board" and marked as C2.
Again the higher ups were pleased with the fact they'd change a board for £80.
One property I went to they'd changed it and there were gaping holes on the top. The tenant informed me the bloke turned up in a car and even checked the rubbish In his recycling bin.
That was a big company that were doing these and they do other services to so one can only imagine the horror they leave elsewhere
Reply to E.I.C.R rant by arti electrical in the UK Electrical Forum area at ElectriciansForums.net
