Discuss Earth arrangement photo in the UK Electrical Forum area at ElectriciansForums.net
Hi All,
Could you please clear for me the air with earth arrangement I've encountered today. Had a minor electrical work moving sockets and went to check the supply. I can see two earth conductors there. One goes to service head which suggests it's tncs and another connecting to outer sheath of supply cable which suggests tns. Slightly confusing. Any thoughts. Photo attached.
TNS
The taped up earth is the earth from the split concentric cable connected to the cutout, the exposed blue insulation you can see where it is split gives it away as a split concentric.
This is very badly done and I suspect it may not have been done by the DNO, I would give them a call and get them to check it out.
It looks like the TNS earth connection could do with some attention too-is that some form of pipe clamp around the cable?
It is a clamp designed specifically for use on lead cables, but the earth wire has not been fitted in the correct place.
The right hand brass wedge has a cutout in it where the conductor should be placed to hold it firmly against the copper plate.
The right side cable looks original (TN-S). The left side cable is newer and is either replacing the original cable which may have become faulty or is a secondary supply to somewhere else, who knows. As above get it checked out.
Reply to Earth arrangement photo in the UK Electrical Forum area at ElectriciansForums.net
Evening Chaps As can be seen in the attached photo , the incoming supply cable has a Earth soldered to the outer sheath of the cable suggesting...
Please can someone explain if this is a TNCS or a TNS earthing arrangement because it looks like both to me. Old undersized main bonding conductor...
Afternoon all I am looking for some advice as on what to with the suppliers earth after a conversion to a TT system. Current issue is earthing...
Did an EICR that passed 5 years ago Several things in the picture raised concerns for me. Comments please - photo at end First photo shows a...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
