Discuss Earth Bonding garage framework required? in the UK Electrical Forum area at ElectriciansForums.net
SSE
Should the framework for my garage door be bonded? It is just controlled manually, it's non-electric. The framework is just bolted to the blockwork? Pictures below.
generally not, but test it. IR tester and wander lead from door frame to MET. if it reads over 22Kohms, then don't bond.
If it's not part of the electrical system or extraneous then no. Simples.
It looks like you left your hex key on the floor.....
Thanks, I'll do the IR test tonight.
Again thanks, will do IR test to see if it's extraneous & the hex key has been picked up already but good observation. :smiley2:
Reply to Earth Bonding garage framework required? in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Hi there, long time lurker, first time poster here. Straight down to it.. A friend asked me to add some sockets and additional lights to a small...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
