Hi all,
My first post-don't be too hard on me!
I'm bonding an existing 3-phase power supply (150mm2 SWA cable) to various incoming services: Sprinkler main, water, compressed air, gas steam & condensate etc. According to BS7671, I can run 35mm2 wire. The run to first service from main earth terminal is about 25m but once there, services are max. 2m apart.
Is it allowed to crimp 2 x 35 wires into say a 70mm crimp ring connector to jump from service to service? Although the conductor is cut, it is permanently joined together. Could even run solder into crimp terminal.
The other issue I have is connecting such a large lug to 15mm copper pipe clamp(s). There is no mention in regs. about possibility of an auxiliary earth terminal, then radiating out from such a terminal separately to each service. This would save so much wire.
Regards
Dave
Regards
Dave
