Discuss Earth Continuity Testing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As part of my new job, we are required to test existing DC Power Racks for Telecoms. We are told to carry out a earth continuity test, then a IR test, then a ELI test.
I may be getting a little complacent the older I get, but surely Earth Continuity is slightly OTT?
I mean, we're proving an earth when carrying out a ELI test are we not?
I know parallel paths can affect readings etc, but nevertheless I feel its too much. I'd like to hear your thoughts please?
L
Of course it's necessary, and you've explained why in your own post.
It's just an R2 test an it takes a matter of min with a wander lead.
Is this what the customer has specified?
I'm sure they will have lost expensive electronic equipment to people not following their procedures.
so what if you the op miss some thing ,ops fried .
Yes, but but telecoms gear is likely to be able to handle it and it's going to be harder to miss something in telecoms racks where all of the equipment is one place.
Plus you'd hope there's some kind of plan, permit to work system etc in place to make sure that kin dof accident doesn't happen.
Reply to Earth Continuity Testing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
