A
acestu
Hi, I have just purchased the martindale socket tester EZ150 which gives me an earth fault loop reading, now i plugged it into the sockets in my mates stables and the green light in the middle came on instead of the first green light, would i be right in thinking that if i have a 32 amp breaker feeding the sockets then the EFLI should not be above 1.44 ohms if so the middle green light 1.7 - 5 ohms is high, do i need to investigate this.
The stables are fed from a three core armoured and the house is about 200 feet away, i have been taught that you should not export the earthing system, so should i devorce the earth at the stable end and put an earth rod in ?
cheers
Acestu
cheers
Acestu
