- Reaction score
- 1
hi guys
tumble dryer is tripping the rcd ,tested the rcd 0.5, x1 and x5 all worked out ok, even ran a extension lead from the house to the tumble dryer (normally fed by sub-main in outhouse) turned on and tripped the rcd in the house,
1) now i was wondering if there was a way to measure the fault current, maybe by connecting a ammeter to the earth at the plug and the metal casing? any ideas ??
2) also does anyone know why when you test at x5 it normally knocks out the main C.U rcd rather then the sub main from which you are testing
cheers in advance
cheers in advance
