Discuss Earth not connected on a socket in the DIY Electrical Advice area at ElectriciansForums.net
MikeeF
I was going to swap a socket in my house for a socket with USB connection. I started to remove the socket and noticed that both earth wires from both cables (part of a ring main) are wired into the metal back box and no earth connections into the actual socket see photo. Now I'm sure this is incorrect and the earth wires should be connected to the socket? The house is 2 years old. Thanks Mike Earth not connected on a socket 20221112_191220 - EletriciansForums.net
westward10
Staff member
Admin
Mod
That is definitely incorrect however it would have an earth connection once screwed back in place but this may be tenuous. Both of those earths need disconnecting to the socket front plate. It is essential the other sockets are checked.
OP
M
MikeeF
Thanks. I will move the earth's to the socket. Luckily I distributed have anything plugged in that socket.
brianmoooore
25mm box where there appears to be plenty of room for a 35mm!
A good electrician would also add a wire between the socket earth terminal and the terminal on the box.
littlespark
Is that socket on the picture a USB already?
This square part here?
Earth not connected on a socket 253E87B9-ECDD-4BC2-AE7E-9B38E3D99EE0 - EletriciansForums.net
I’m with Westy.
Check all your sockets. In fact… check everything. 2 years is still under the NHBC warranty period… although that’s not always worth the paper it’s written on.
Look out for missing brown sleeving behind lightswitches.
And loose cables.
Please isolate any circuit before taking fronts off
Might be interesting to see the consumer unit,
OP
M
MikeeF
I’m with Westy.
And loose cables.
No it's not a usb. Yes I will be checking all sockets now.
Reactions: DPG
Reply to Earth not connected on a socket in the DIY Electrical Advice area at ElectriciansForums.net
Hi everyone, I've got a garage with a circuit that looks like this: I believe it's a radial circuit coming out of the MCB with a current...
I guess there are a thousand question like this, but I couldn't quite get if I can do this myself or need an electrician. I have a garage...
Evening, I’m wondering if someone could give me a little guidance. Whilst removing some old carpets I pulled out what I now believe is the BT...
After turning off the main panel's utility 150A breaker, can I plug generator's 30A output into dryer's 30A socket to backfeed? I know it is...
For emergency use, when there's a power outage, the current situation (no pun intended) is that I'm running a hook up cable from the 16A socket on...
New Posts (Please Reply)
