Discuss Earth Test showing >2000 ohms? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
DanBrown
Hi Guys..
Kinda new to this testing, but yesterday i did a earth loop test using the Fluke 1653 tester.
I put the prongs on E-L-N and did the test. The reading i got back was >2000 ohms. Indicating a open-circuit. I didnt have too long to look into this further but i do know that i had a earth because when i did a voltage test across L-E it indicated 243v.
The test was done on a commercial building with several distribution boards, if this matters.
Thanks in advance for any feedback...
i think one of your probes wasnt quite touching the terminal mate.
if you didnt have an earth it would come up error 4
Reply to Earth Test showing >2000 ohms? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hi all, Would like some advice on the below. Context: Rural French domestic installation TT system Earth rod is situated inside the property...
Hi folks. Im a RECI contractor based in Co Sligo, Ireland . I was doing erroneous testing on a domestic board which gave me readings between 90V-...
Looking for some guidance here. I'm currently shadowing a guy and we're testing a new extension on a school. 3 phase TNCS supply from the original...
Earth to Neutral 2 ohm with Multimeter on alighting cct. The cable disconnected from the switchboard. I am new here and appreciate everyone...
