Discuss Earthing for electric vehicle Charging in the Electric Vehicles Advice Forum area at ElectriciansForums.net
J
jandardo
Hi
I have a job to install a electric car charger, it is to be situated just outside an indoor car park. In the IET code of practice i can use the PME earth if it is located inside the building but must use TT if outside. MY problem is the isolator has to be fitted inside the building but the charger is outsde right beside the metal frame work of the building so i am unsure what to do. Anyhelp would be much appreciated.
If your charging point is located outside and cars will be charged outside and because you have the building structural steel adjacent to the location then your only realistic option is to have a charging point with an isolating transformer and the charging point isolated from the PME earth. You would not otherwise be able to comply with the requirements of the code of practice.
Reply to Earthing for electric vehicle Charging in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Electrical2Go is proud to announce that we now stock eVolo EV charge points. eVolo is the new sustainability brand by Deta Electrical. These EV...
Hello, I am an enthusiast amateur undertaking wiring of two outbuilding under a building notice. I am soon to be subject to a first fix inspection...
Just looking for a bit more information on Mode 2 charging of electric vehicles. The mode 2 charging cables state they have protection against...
I am installing a Victron Quattro in an island mode configuration (in the UK, the DNO is the NG). I will be adding a stand-by generator. My...
Hi guys I was recently ask by a customer if/how his house could be supplied by his electric car. He wants to charge the car at night on low rate...
