Discuss Earthing mat is making me ill ! in the UK Electrical Forum area at ElectriciansForums.net
Are you familiar with the significance of a resistance in the order of 100 megohms?
Please confirm what resistor is fitted to your cord. I would like to discuss its significance but it is important to get the numbers right, as the ratio between a kilohm and a megohm is the same as the ratio between an hour and six weeks.
This is the exact mat that I bought but it doesn't mention the resistor value. I've sent them a tweet and will update when I hear back...
Thanks bud!
Thanks bud!
So I got a reply, they're saying it 100k ohm. I've confirmed this using the multimeter set to resistance and connecting it to both sides of the cable and also Clint Ober (the original creator of the first grounding mat) has confirmed that he uses 100k ohm on his mats
If you think it's making you ill, disconnect it, roll or fold it up, and place it in the bin.
Then stay away from pseudo scientific drivel on social media or the internet, placed there by persons whose only interest is in parting you from your money.
Do you know The different between pseudoscience and real science? Because the grounding mat… is real science…. Studied for years… with research articles and clinical trials…. With results…. Positive results…..
Do you have a link to any of these studies?
I can see where the OP is coming from with the Earth mat and skin melanoma.
Whether it works or not is another question, to me it sounds a bit like the rife machine approach How to Build Your Own Rife Machine or TENS Unit - https://eternalspiralbooks.com/how-to-build-your-own-rife-machine-or-tens-unit/
Personally if it was me I'd spend money on the food approach, I wish you well OP!
Reply to Earthing mat is making me ill ! in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I'm new to Amtech/Trimble and I've been asked to review a model. I'm looking at circuits that are SWA cables using the armour and an...
Can anyone advice me on how to take in the effect of Ground Enhansing Material (GEM) used in Electrical Earthing to reduse the earth resistance...
This question has probably been asked several time but things change. The house I'm living in now was built in the 1960's and has a ring main...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
I am a complete novice when it comes to electrics but I have recently bought a grounding mat and so I've been doing some measurements and I'm...
