Discuss Earthing selv lights in the Electrical Forum area at ElectriciansForums.net
repair cable then. might be some slack above ceiling.Thank you telectrix. Or, in theory, could I cut a large hole in the ceiling and shove the transformer up there, DON'T BE SILLY. away from the light fitting ? The cpc has been cut back.
It is, yes. My concern is that with the transformer sitting in the fitting there is 240v present there and the outer sheathing has been stripped back.
SO. What type of enclosure would you fit the transformer into?Why is it silly telectrix? Isn't that how downlighting is fitted?
so you'd have exposed live terminals in the ceiling void?????Enclosure?? Up in the ceiling void! Ventilated.
They are talking about the transformer/driver metal casing I think wilko on the supply sideIf the fitting was to be earthed, then it's no longer SELV I thought. That may not matter here, just saying.
i use these, but am running out, and looks like the supply has dried up:I like tel's idea. Use a JB with cord grips though.
Reply to Earthing selv lights in the Electrical Forum area at ElectriciansForums.net
