- Reaction score
- 51
Hi, have an easikey 1000 plus control panel which controls two fob readers either side of the gate with an emergency switch, now someone’s been and reset the panel feeding the box and now the fob only works when entering the gate and doesn’t work if you exit there’s a red light that flashes green to say open and it comes up open on the control panel but will only open on one side of the gate if you try on the other side nothing happens just flashes green but doesn’t open, there’s a magnetic strip but doesn’t open on one side, any one know why? Does it need reprogramming I have the master key but am at a loose end theres voltage for each reader and signal to panel but no luck
