Discuss Easy connection help seek in the UK Electrical Forum area at ElectriciansForums.net
Hello!
I am a novice in this electricity world, however I'm trying to learn the basics, I have this centrifugal fan which came without power cable and I had to connect one to a 3 way terminal block but on the diagram I could only see where to put the N and L cable, the ground cable there was nothing on the diagram or any indication where to put it, I'd like to ask you for your knowledge to where should I connect this ground wire.
Sorry about my lack of knowledge, I'm learning new things everyday
20190926_120608.jpg 20190926_120612.jpg 20190926-095838.jpg 20190926-095921.jpg
The first photo I believe is correct. You just have to connect it to the spare terminal. The fan itself doesn’t require it by the looks of it, so it’s safely parked there.
I will say that the cord grip should be tightened onto the outer sheath of the cord and not the 3 inner cores
Reply to Easy connection help seek in the UK Electrical Forum area at ElectriciansForums.net
Was helping a friend out and changing their CU which had a date stamp from 1990. Good quality Merlin-Gerin unit and a nice job originally. They...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
