Discuss Eco 7 teleswitch in the UK Electrical Forum area at ElectriciansForums.net
H
highspark
Working on storage heaters and seem to be getting a 100v reading from teleswitch when economy hours are not on.... Any reason for this? Possible causes?
Induced voltage from live circuits running near the ECO7 circuits?
If you have a real 100 V then the storage heaters would be heating somewhat when off as 100V would be enough to cause a resistive heater to operate.
If it is a real voltage and you have disconnected the Economy 7 circuits and it is only at the teleswitch then call the supply company.
If you have an E7 CU then switch off and check for which side of the main switch the voltage is present.
Voltage is coming from the incoming side of the E7 CU so from tele switch. Once main switch is isolated at CU no voltage at storage heater circuits. Tested voltage from the outgoing live terminal of tele switch and still getting the same voltage (about 120v).
other than the tele switch being knackered I'm baffled.
Reply to Eco 7 teleswitch in the UK Electrical Forum area at ElectriciansForums.net
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
There was always talk of teleswitch transmitters being switched off. Does anyone know if that is a thing, or whether it’s been done? I was at a...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Hi Guys, Had a call out today about an odd issue with a newish Creda DT storage heater. Basically.. Storage heaters were installed in one flat...
