Discuss economy 7 in the Australia area at ElectriciansForums.net
R
Ross Trician
Morning all,
can someone tell me if it is possible to force on an economy 7 supply for storage heaters?
I am going to look at a heater for someone that they say isn't working but then it occured to me that there will be no supply to it in the day when I am there.
I am not familiar with economy 7 at all and dont recall ever working on it other than to remove it when someon had cental heating installed.
thanks for any help, Ross.
yes you can. is much easier on the old mechanical time switch, simply open the cover and there is a slide switch say 'off' 'on' and 'auto'. will prob be set to auto.
simply slide it to the on position. when u've done and you slide it back to auto it will stay on untill the next off time (which you prob dont want). so slide it to the off postion then to the auto position. the heaters with then stay off until its time for them to come on
Your not really supposed to open the meters, and will prob be sealed. no one seams to care these days tho
hope it helps
I use a length of flex connected to a plug top on one end, then undo the double pole switch and disconnect the off peak feed and connect the flex, then just plug it in, works a treat and you also check the d/p switch is working at the same time.
Just done a rewire and i need to connect the economy 7 back to the seperate Cu. But I dont have a clue what goes where. Ive 4 terminals at the suppliers economy 7 meter live supply, 80 a load which are obvious. the other 2 are RXN and 2A tarrif terminals, where do these go?
Figured it out now
Reply to economy 7 in the Australia area at ElectriciansForums.net
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hi all, I have an Economy 7 storage heater Dimplex CXL24N - 3.4kW Storage Heater + Convector ( there not available anymore) that dos'nt work and...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Yesterday moved my Mum into her new bungalow. The Hortsmann had been off for a few months I suspect. The boost worked, but nothing happened...
