Discuss EIC help what would you put in the UK Electrical Forum area at ElectriciansForums.net
what would you guys put;
Part 7 ; supply and earthing arrangements I have EB incoming which is TNCS earthing but then is split to TT would you tick both?
Part 8 ; says Maximum demand (load) what would you put I have 2X 160 amp BS 88 fuses
The supply characteristics cannot be both TNCS and TT. If it's TNCS at the service head then that is the supply characteristic. If it separates to TT downstream then state that in the 'extent of work' or 'comments on existing' as appropriate. If the installation is new then it is appropriate to calculate the max demand. If it's an addition or alteration then I use the OCPD rating in amps at the intake as the max demand.
I don't get what you are describing. There are two fuses? So does that mean two cut-outs? one TNCS the other TT? How do you know it is 160A fuses? Is there a piccy?
Reply to EIC help what would you put in the UK Electrical Forum area at ElectriciansForums.net
Good morning Guys Looking for some advice with regard to a current job. Building company I'm doing work for are installing...
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
Hi guys I was recently ask by a customer if/how his house could be supplied by his electric car. He wants to charge the car at night on low rate...
I have been asked/invited to "post more", lol, so let me make another post right away. I thought of sth worthy to post, of interest to many, I...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
