Discuss EIC Questions in the UK Electrical Forum area at ElectriciansForums.net
i would reserve new installation for a complkete install/rewire. CU as alteration.
I normally put CU changes as new, due to the fact that I am fitting a "new" item. I not altering the wiring in any way.
Thats my take on it anyway, but I guess its your call and how you define it.
Sav
Awaiting to be corrected !!
Haha, love how everyone has a different take on categories. Maybe the IET could add a "New CU" box and make everybody's life simpler :)
Must admit, I normally have a new circuit to add whenever I carry out a CU change so I get the "addition" box to tick....but then again, it's an "alteration"........... :willy_nilly:
Alteration and annotated 'new CU fitted etc etc etc'.
Sav
so if you have to extend the existing cable/s...is that not altering the wiring then?!!....
and if the cables dont need to be extended ?
It does happen you know.
like I said, its up to the installer to decide in their professional opinion.
I dont think there is a wrong answer here
Change a rewireable cu and to an 60898mcb / RCD type and you are affecting all circuits including ELI aswell as VD calcs altering the whole installation hence new regardless of pre existing wiring as its capability changes as a consequence .
Regardless of what you change, or what is affected, a new installation is just that... a completely new installation. That is what the form means at any rate, regardless of interpretation.
- - - Updated - - -
Can't see an issue. Self explanatary. You can always tick more than one.
As we often have to when online notifying :)
Reply to EIC Questions in the UK Electrical Forum area at ElectriciansForums.net
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
Hi, just a quick question, to anybody using the ICertifi software, has anybody else noticed that the EIC certificates have now changed? They now...
Hello, I am in the process of training to be an electrician and have a question. When filling out a EIC for a new circuit am I required to test...
