Discuss EICR certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
On an installation there are two main switch’s one in a 12 way DB, another is an exel switch fuse supplying two DB’s. What would you put down as the main switch on the cert on page 2?
i'd be doing a schedule of test results for each DB. then on each put the main switch details for each. on the inspection section, note saying "see DB schedules"
It's asking for the main switch, there is no main switch. What would seeing the schedules prove.
my bad. was looking at an old schedule where each had a main switch details for the DB.
If it has no isolator from DNO and the origin of supply is split then the most comprehensive way would be to complete 2 seperate certs.
It's no different to having a unrestricted and off peak supply at a house, some people do it on two certs and others just add a schedule of inspections and a schedule of tests, not right really but not a big deal in my eyes.
Reply to EICR certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello, I had an eicr done in 2021and it passed with four C3 items. They recommend next test date to be in 3 years instead of 5 on the certificate...
Hi all, Been asked to do EICR on thatched property for insurance purposes, however they will want all C3 codes rectified. Haven't seen it yet but...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
