Discuss EICR coding help in the UK Electrical Forum area at ElectriciansForums.net
If the child has the motivation to enquire whats under the cover,then manages to find the right tool to remove that cons unit cover,then further investigates by removing the bus bar cover,he is probably on course for a apprenticeship
^^^ This. I'm sure most of us have similar stories.
My interest started around the age of 9, when I'd buy & 'smuggle' flex and Duraplug connectors into my bedroom to make extension leads, which I took into school and used on the overhead projectors in assembly. Long before the days of ISITEE... anyway mine were better than the broken pattress boxes stuck to a piece of skirting board that the Maths teacher had made :cool:
Indirect contact is an old term no longer used in BS7671. It means getting a shock from something which in normal circumstances would not be live like the casing of a Class I appliance. The other term is direct contact which is obvious.
Don’t no why they felt the need to change it personally
It was to harmonise. So protection against direct contact is basic protection and protection against indirect contact is fault protection.
I'm still annoyed they chose to rename phase conductors line conductors though!
Reply to EICR coding help in the UK Electrical Forum area at ElectriciansForums.net
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Just had an EICR done and C2 (dangerous) applied to 3-way consumer unit which is exclusively for 3 x Storage Heaters. Pic below. Yes its plastic...
Hi I am carrying out an EICR. I have a garage mini sub DB supplied via 2 x 2.5mm T&E equivalent 5.0mm protected at main DB by a 32A mcb. I know...
Hi, I have a property that I was looking to rent out. Its 12 years old property so relatively new. I had a EICR done from a qualified electrican...
6K
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
