- Reaction score
- 12
Obviously at least a C3, but is it a C2?
Front door opens into tiny hallway, not much more than 1m square with the stairs going straight up virtually in line with front door, approx. 300mm offset to right.
Above you as you enter is a 16th edition insulated CU, tight against the ceiling and tight against the wall to your right as you walk into the property.
To your right is the door into a kitchen diner with sliding patio doors.
To your left, approx. 600mm, is the door into the lounge.
Therefore the only exit route from upstairs is either out of a first floor window, or down the stairs past/under the CU.
I'm sure I recall a non Amendment 3 CU under standard wooden stairs should be considered a C2, because in the event of a fire, not only does it have the potential to cause the stairs to fail, but as this would be considered the normal escape route in the event of a fire it would also be the source of smoke and heat making safe escape harder.
So, would you consider the situation described above;
a straight forward C2, or
a potential C3 with strong recommendations to fit an Amendment 3 CU, or fit the existing CU in a non-combustible enclosure?
I would typically err on the side of making it a C2 to cover myself and argue a lesser coding should objections be forthcoming about my making it a C2, i.e. what price/cost safety.
