Discuss EICR coding question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Came across this on an EICR and was wondering how everyone else would code it. Basically there’s a sangamo time clock that controls a contactor which switches a 3 phase DB for storage heaters, strange set up in a flat. So you’ve basically got 6mm cables in this sangamo time clock that are protected by the supply authority fuse, would you code that a c2? Main fuse is 100a. Would be better if this was being supplied from an mcb I would say
An inline fuse would normally be fitted in cases like this. Similar to what you might find in the old Heatmiser off peak water heater system.
From your description it sounds like you are trying to code the DNO / electricity suppliers economy 7 time switch
Reply to EICR coding question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Hi, Currently undertaking an EICR on a factory, we have came across an 4 core SWA and 4 Core SY which have been split in the DB to serve two...
Hello guys n gals, Did n EICR other week in a flat where the shower circuit was 40A mcb with RCD protection, 6mm cable. Only about 10M run. The...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
