Discuss EICR coding in the UK Electrical Forum area at ElectriciansForums.net
Is it any different to having a straight batten holder in the ceiling?
Must admit my initial thoughts was c3 as the top of the lamp is 300mm from combustible surface but also it’s a twin arm candle holder type wall light and the sides of the lamps are only 150-200 away from beamed wall so maybe I’m over thinking this. There’s no signs of any overheating etc
No code, it would take a lot more than an incandescent lamp to cause an oak beam to catch fire.
In Ireland RECI are quite strict about luminaries too close to combustible surfaces and would expect it changed for an LED luminaire marked as suitable for mounting on/near combustible surfaces with non-replaceable lamps.
As such it's something I would avoid.
How exactly is combustible defined by Reci?
I can appreciate if it was a readily combustible softwood being discussed here, but Oak just isn't readily combustible.
Oak and a few other hardwoods have been tested by various companies who manufacture wooden switches for suitability as enclosures for electrical connections and they pass.
It's an interesting question, and I suppose you could try to argue that with the Inspector. I'm not sure whether they have considered the properties of different types of wood or not. With the move to LED lighting though I suppose it's becoming less and less of an issue.
Its the same question that there still doesn't seem to be an answer for regarding consumer units.
There are standards and tests out there which test combustibility, but no answer as to which one should be used in these situations.
Reply to EICR coding in the UK Electrical Forum area at ElectriciansForums.net
Another thread asked about two circuits sharing a common multi-core cable and regulation 521.8.1 was mentioned. A friend of mine has inherited...
Hi all. I have a small question about inspection interval labels. We all know to fit one of these labels with the relevant date upon completion of...
Hi guys Completed an EICR yesterday. One of the Sockets Radials had no CPC so R1+R2 plus Zs could not be not be completed. Does anyone know the...
Hi everybody, I've been asked to do a EICR in a commercial property, So i popped in to have a look on my way home quickly and found the lighting...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
