Discuss EICR-down lights cpc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
aes2011
EICR of a semi detached house. Wiring approx 20 years and in flat twin & earth.
I have found the following condition;- cpc's present but not connected at down lights on Downstairs lighting circuit. Joint box method and has been established there is an earth to JB. Down lights and other circuit accessories are all class 2.
What code would this observation warrant?
Cheers
no, because that only applies if the circuit has no cpc. in this case the cpc is present at the JBs and so could be connected to any class I fittings. i assume that all switchesw have a cpc to the back box ( and faceplate if metal)
Reply to EICR-down lights cpc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I've tried to research and form a plan without asking on here, but I'm just going around in circles. Just completed an EICR. The wiring ranges...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
I have a light switch where the CPC has been used for a lighting circuit and sleeved. Previously I would give this a C3 (411.3.1.1) and leave a...
I would greatly appreciate if someone could help me understand the following outcomes on an EICR. I am being advised it needs a total rewire but I...
