Discuss eicr form filling in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
hi everyone
been reading this forum for a year now and this is my first question i just hope i am doing this right.
on TT earthing we have one box for RA and one for ZE, what box do we use.
It depends on what you are measuring.
With most installations where an RCD is used and accuaracy is not really an issue, it's acceptable to measure the Ze, the same as you would with any other installation.
If however you are measuring the resistance of the electrode, and a degree of accuaracy is required then you would measure Ra.
as spin says, in general you just measure Ze. measuring the actual Ra is a bit more complicated, and is generally used in industrial installations.
Reply to eicr form filling in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Hello there. I've been looking around here and found some conflicting information. I have a question if I may ask. I had an electrician come over...
4K
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
