Discuss EICR + Heat detector Query in the UK Electrical Forum area at ElectriciansForums.net
Hi these are two separate queries,
First off,
What are the minimum requirements for someone to carry out an EICR. I thought it was this and that but basically someone told me that you dont really need anything, just competence which can be ascertained by basic things i.e. ecs card no?
I thought at least the appropriate qualifications and registration to a governing body such as nic or nappit?
Any clarfication would be appreciated.
Secondly,
If someone were to install a heat detector, could this be added to an existing circuit such as lighting or should it be run on its own dedicated circuit, I would assume a fire alarm system would need a dedicated circuit but presumably a smoke alarm or heat detector are less affected by the possible implications presented by using a non-dedicated circuit.
Regards
First off,
What are the minimum requirements for someone to carry out an EICR. I thought it was this and that but basically someone told me that you dont really need anything, just competence which can be ascertained by basic things i.e. ecs card no? Competence only.
I thought at least the appropriate qualifications and registration to a governing body such as nic or nappit? No, not currently necessary.
Secondly,
Regards
In answer to the second part there is a difference between a heat detector (component of an alarm system) and a heat alarm. You seem to be mixing terms so it's not clear what you're asking about.
Thanks for prompt reply,
So in order to carry out EICR you don't really need anything apart from a piece of paper and a MFT?
And, from the query brought forward to me, it would be going inside a domestic dwelling and as such I believe it would be, using the correct term a heat alarm. I do not think it would be wired as a component of an alarm system.
So in order to carry out EICR you don't really need anything apart from a piece of paper and a MFT? You need competence, as said.
It is prefereable to either use a dedicated circuit for smoke/heat/CO alarm circuits. An alternative is to supply it from a regularly used lighting circuit (ie downstairs lights), if this is done it's recommended to provide an means of isolating just the alarm part of the circuit, it has been said that the ability to remove an alarm from it's base is sufficient to satisfy that (it's not a reg as such but is recommended in the OSG).
To carry out any electrical inspection you need experience in the type of installation you are inspecting.
No quals , schemes , or trade cards needed.
However having 2391 proves your understanding has been assessed to an industry approved standard.
Reply to EICR + Heat detector Query in the UK Electrical Forum area at ElectriciansForums.net
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Prompted by the other thread.... I had a slight dilemma on this topic a couple of days ago. Three mains smoke alarm bases, on their own circuit...
Hey all, Could do with some help. I had a company recommended to me who quoted me to do an EICR on my rental property. (£265). I thought this...
