dudleydoright
Well lads some advice if you please
Looked for Quoting to do an EICR in a church with the following items from a PIR done 14 months ago.
1) Lightning conductor box on PIR cert was ✓ N/A. (It has a lightning conductor) my question is does the lightning conductor require connection to the MET Terminal. If so what code for no bonding to MET.
2) The existing PIR cert is for a single consumers unit which only appears to supply the Church. There are further 3 consumer units all supplied from the same intake with a single metered supply.
Should the EICR not cover the whole building and not one part of it? The Other consumer units I, am told have separate PIR’s
