- Reaction score
- 148
Hi Guys, Recent EICR carried out at a Church & Hall. Would you code no SPD present at Supply origin & should the Lightning Protection System be connected to the Main Earthing Terminal via another SPD.
Discuss EICR no SPD &LPS Enquiry in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
No but it was recently checked & passed according to the Church Warden.Have you seen a copy of the report?
Itas all down to the survey you carry out on the installation, the book has a map of areas prone to strikes, and the equipment that may need protection in the propery , for example a house with the THTC set up with sometimes 3 boards why would you want to protect storage heaters, and convectors, I only consider the house circuits maybe the boiler if its got electronics for example there is no set rule for all properties, Lightning conductors I would not be encourging lightning to find a path into the home via the METHi Guys, Recent EICR carried out at a Church & Hall. Would you code no SPD present at Supply origin & should the Lightning Protection System be connected to the Main Earthing Terminal via another SPD.
Reply to EICR no SPD &LPS Enquiry in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
