Discuss Eicr / pir in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
AdamDee
I am doing a periodic inspection tomorrow and am confused on what paperwork I have to fill in?
Can I issue a periodic inspection report or do I have to issue the new EICR 8 page certificate?
It might be a stupid question but I dont do that much testing, thanks for your help.
There are some confusions around all this.
In a nutshell.
You are still carrying out a Periodic Inspection and Test of an Electrical Installation, Check the regs or whatever, and you will still see that this terminology is still in use.
On completion, you will issue an Electrical Installation condition Report, and a generic Schedule of Test results. What you wont do any more is issue a Schedule of Inspections, as this form is for new installations only.
Dont fear the changes, the EICR is very straight forward to complete, you just need to get used to it.
I personally think it is easier and better than the old way.
Have a look in either GN3, OSG or BRB for examples of the EICR, or download it from somewhere.
Cheers...........Howard
Reply to Eicr / pir in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, Been asked to do EICR on thatched property for insurance purposes, however they will want all C3 codes rectified. Haven't seen it yet but...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Hello everyone, I'm wondering if someone could help me with some EICR coding. I am aware that bringing mains tails into a fire rated consumer unit...
Refurbishment of dwelling has taken place and the clients insurance company requires a periodic inspection and test to be carried out, A new...
Hello, I had an eicr done in 2021and it passed with four C3 items. They recommend next test date to be in 3 years instead of 5 on the certificate...
