Discuss EICR Pricing for Small Commercial Premises in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
arcbrightmike
Hello Fellow Sparks
Just trying to sort out a price list for one of my clients who wants all of hes 12 cafes around London tested this year. I was just wondering if anyone thinks that I am doing it too cheap or too expensive or if I am missing something
Electrical Installation ConditionReport (EICR) Prices
Minimum Charge £250.00 plus anycharges such as parking and congestion charge and out of hours workwill be charged at £50.00 on top of the final price.
Circuits are defined as final circuitssupplying power, lighting or equipment, distribution circuitssupplying distribution boards or isolators and also including mainearthing and main protective bonding conductors.
Circuits Price
01 - 20 £15.00 each
21 - 40 £12.50 each
41+ £10.00 each
Thanks in advance
Read a post here the other day (Des 56 I think) which is pretty much how I price it up.
40 mins per circuit + 40mins per DB, multiplied by your hourly rate.
Checking 100%? Every single socket, switch, and light fitting gets removed and checked?
Exactly my point, you'd introduce more faults than you'd identify.
100% test yes, 100% accessible visual inspection but a sampled detailed inspection.
Sampled detailed inspection isn't a short cut.
I do mean look at everything, the stuff I have come across warrants it. Also I understand it that if you come across one fault you need to check 100% anyway.
If you started on a 30% sampled detailed inspection, you wouldn't normally jump to 100% after 1 fault, you would increase your sample percentage and continue to do so should a pattern of defects emerge.
The sample percentage is there to prevent the introduction of faults and defects due to dismantling, it's all in Guidance Note 3.
Reply to EICR Pricing for Small Commercial Premises in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Is there a room in professional PAT testing for a business model other than 'per unit'? I ask because I've been giving this some thought. I've...
9K
A
Hi, I am new to this forum I'm just after a little advice regarding an EICR I am doing and wondered if somebody could help me. I am just...
Deleted member 26818
ElectriciansOnCall are a Kent's premier and most accredited electrical contractor covering all CT and ME postcode areas. From changing a faulty...
M
Hi all, hoping someone could advise me on. Im a sole trader domestic installer with Elecsa. I am being increasingly asked to to installations in...
T
I have been asked to test my friends renovated property, fully rewired, and said i'd do it for £100. He is a qualified spark but i did check his...
Welchyboy
W
