Discuss EICR test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You haven't given the floor to ceiling measurement, but that ceiling doesn't look unusually low.
I doubt if the bottom of the lamp is below 2.25m, in which case there's nothing wrong.
If it is, it would probably pass if you took the lamp out!
Makes you wonder how many letting agents are trying to force people to get repeat EICRs done after minor work is carried out.
To be fair, if you issue electronic certs, it doesn’t take 5 minutes to remove all C2’s / C1’s and amend the observations once the remedial work has been carried out, then reissue a satisfactory EICR.
it’s what I do and certainly don’t charge for it.
I do this all the time, did one this very day.
PIR done 2 weeks ago, open live on the kitchen, went back to day, found the fault and repaired it and a couple of C3s he wanted sorting. Just edited the EICR then reissued.
Reply to EICR test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Private tenant since 2011. First ever eicr February 23 informed via text it failed by text from electric secretary arranging appointment for...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
I paid an electrician for an EICR test - two of his men took 3-4hrs to do the test. This was on 28/04. He since told me that the test failed and...
Hi, recently had an EICR test done by 'Landlord Certificates' which failed due to circuite 3 having two radial circuits into a single 32amp MCB...
4K
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
