I think this is a good question. What is a good figure? This question has been asked before and the answer is their isn't a given figure. I don't see how you can 'estimate' a length for the bonding if you can't find the incoming water supply. If you can then that's a different matter and you could then estimate from the known resistance figures for a 10mm conductor. But if you could see where it enters the house in order to make an estimate then you'd be able to test to see anyway if adequately bonded by using the 0.05ohms suggestion in GN8 (measuring between known earth and pipe), so I'm guessing Jo can't find where it comes in?
If you can't find the stopcock or where the water enters the house and can't find the bonding, then I would put it down as further investigation required as its a pretty important aspect to put down as NV.
