Discuss Eicr in the UK Electrical Forum area at ElectriciansForums.net
dlt27
Hi all, I have done a few EICR's before however could do with a bit of advice on what codes you more experienced guys would give these observations;
1 Old 3036 DB made up of wooden base/back. (C3?)
2 Underszed main bond. (C3?)
3 Cooker switch mounted 18" above cooker (C3?)
4 Mutiple cct's in MCB (C3?)
Thanks for any input.
There is no correct answer but you need to be confident with your own answers. Off the bat without seeing I would say:
1) C2 - wooden base DB coukd potentialy be dangerous.
2) C3 - as long as continuity is adequate.
3) C2 - potentially dangerous
4) C3 - as long as OCPD is rated appropriately to the conductor sizes.
1,2,4, no code. maybe a comment for 2 & 4.
3. C3.
IMO.edit: 2. code if <6mm.
i think I'd probably agree with this and say the same.
It's all a bit open to interpretation isn't it, probably thinking about it make the cooker switch a C3, the DB with wooden back, thinking about it again, I'd be C2.5, sitting on the fence.
The NIC do a testing and inspection on site guide, which will be going on the cheap now because of the new rules. There's a quick guide to codes in it, which is handy with the codes and regs numbers that correspond to them. 99% of them will still be good
How can multiple circuits be in one MCB? It's one circuit!
If that's an EICR coding every new install I do will have a coding as the Smokies and a commonly used lighting circuit (yet to find an uncommonly used lighting circuit in domestic!!) are in together.
Any body has a wooden CU tell them they need a rewire, ask them if they can afford it and get out of there. Do not do anything last man in is responsible fail it on a visual charge them £30 quid and get out of there.
I recently done a niceic solar course down south. The guy carrying out the course also carried out courses in eicr's. I put the question to him about what codes I should put to various observations ie ones that were safe but not up to current regs. (Ones I didn't think deserved a code). His reply was that anything that wasn't up to current regs. should be a code 3 because it would enhance the installation . I asked well why do away with the old code 4 then! I said I thought an eicr was carried out to see if an installation was in a safe condition not to see if it was up to current regs.
However he wouldn't have any of it...
Total and utter nonsense!
Reckon he was waiting for a bite boss!
New posts
Reply to Eicr in the UK Electrical Forum area at ElectriciansForums.net
Hi I am carrying out an EICR. I have a garage mini sub DB supplied via 2 x 2.5mm T&E equivalent 5.0mm protected at main DB by a 32A mcb. I know...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Morning all So the site I'm based at recently had some work done (think partitioners). This package of work included electrical. This was...
8K
