Hi, I'm having trouble with a garage door, was on a single socket on a re-wireable board working fine. Changed the board to an rcbo tried it on a type c 20a and was ok until you tried to open the door and the breaker tripped also tried on a type c 16a rcbo to see if there was a fault with the rcbo and it did the same, this is on it's own circuit. Have opened the door by hand to see if it was catching but seemed to operate freely so don't think the motor is jamming/put under extra stain to open or close.
The door is a couple of months old and there is no paper work with it other than a brochure that says the company uses 'Somfy motor units' from a quick search on google I've found this,
SOMFY United Kingdom - AC Motors
If it is either of those doors the max current usage could be 3.15A, not sure what it draws to start but I'm scratching my head on why the breaker is tripping? It's been a long day and guessing I'm missing something fairly obvious.. I popped the cover off the control unit in the garage and there were two adjustable knobs with fuse embossed on them, no idea what fuses they are for. As you can tell I've never dealt with electric garage doors before so any help would be much appreciate!! Thank you
