Discuss Electric meter change in the Industrial Electricians' Talk area at ElectriciansForums.net
M
mgibson212
Hi Guys
Thinking of opening up a Stand n Tan shop just outside newcastle(NE). Been and looked at the premises and its got a 40A meter installed. How much to get this changed to a bigger meter and which channels do I go through for it.
Thanks, Mark
contact your energy provider as they will be the ones able to look at uprating the main cut-out and prices will vary from supplier to supplier
Couldn't tell you. I guess it depends on the incoming supply and how big the incoming cables are as to what size main fuse they can provide.
Can get sunbeds in both single phase and 3 phase. Single phase you are looking at around 48 tubes at 160W each which will then need a 8KW spur from DB. This gives around 35A on start up. Limits me to one unit at moment
Tube options Capacity(watts) Fuses single phase three phase
44 x 160W
7340 45A 3x16A
48 x 160W
7980 45A 3x16A
60 x 160W
9900 63A 3x25A
44 x 180W
8220 45A 3x16A
48 x 180W
8940 45A 3x16A
60 x 180W
11100 63A 3x25A
44 x 200W
9100 63A 3x25A
48 x 200W
9900 63A 3x25A
48 x 225W
11100 63A 3x25A
60 x 200W 12300 63A 3x25A
60 x 225W
13800 63A 3x25A
Electrical supply on all units: 230/400V-50Hz
Hope this gives you some more info if interested
Reply to Electric meter change in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi all, Very much a novice when it comes to electrics. Anyway, we're getting an EV chargepoint installed, but before we do, I was wondering what...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
