Discuss Electric Radiator in the UK Electrical Forum area at ElectriciansForums.net
Sam081189
Hi Guys,
New on here so please be gentle...
I am a bit stuck, I have just purchased a 1500W electric radiator, and I am stuck between using butyl HR 1.5mm or 2.5 PVC HR, is the 2.5mm a bit overkill ? would 1.5mm do the job? it will be going to a 13amp Fused Spur then back to the CU on its own circuit on a 16amp MCB.
The radiator will be used 4/5 hours of the day.
agree with both above posts. 1.5mm would be OK for 2 of them. (3kW).
Reply to Electric Radiator in the UK Electrical Forum area at ElectriciansForums.net
Hi, I recently moved into a house with electric storage heaters and am looking to replace them with electric radiators. Gas and oil are not viable...
Hello and good morning all. I am putting in a first fix on a small extension. It will have its own fuse board coming from the main house. I plan...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
Just had my design project handed back to me from my last block and I got everything right apart from one question Q9 I would take a photo but...
