Discuss Electric shower pull switch isolator in the UK Electrical Forum area at ElectriciansForums.net
Hi, my neighbour has had to change his electric shower (6kw) pull switch (32A) 3 times in 4yrs. Apart from it possibly being poor quality switches he,s replacing, I was wondering if there is any reason not to leave the pull switch isolator in the "on" position. Thanks
I have never seen a 32A ceiling pull switch. Generally 45A or 50A for shower switches.
The most common cause of these burning out is poor termination causing a loose connection. There can be many reasons for this.
I fit the Crabtree 50A switch as it gives the best termination opportunities as opposed to plate type switches.
There is nothing wrong with leaving it on all the time.
Yes you are correct, it is a 45A. My problem is, it,s me that has fitted the last two for him, although he supplies them ! There has been no sign of bad connections either time. But thanks for answering my core question.
Heavy load Vs Cheap products = burned out
I have seen this on cheap immersion timers etc
Infact I just changed 2 immersion timers for 2 different people , neither timer lasted more than 18 months
Have installed Timeguard now but not cheap at £30 a pop
Are you sure the shower is 6kw and not 9kw..
What make of isolator have you used?
Did you inspect the inside of the shower unit when you replaced the isolator?
1. As mentioned, make sure the switch is a decent quality.
2. Assuming the cables are stranded, after tightening the connections, wait a few minutes and re-tighten. Any loose connections are likely to overheat.
3. Some people use this isolator switch to turn the shower on/off, which can lead to premature failure. Leave this isolator on, and turn the shower on/off at the shower unit.
I leave mine OFF and operate the shower via the controls on the shower, I NEVER SWITCH THE PULL CORD ON LOAD. turn shower Off via controls and isolate via the pull cord.
Thanks SJD, points 2 and 3 have been adhered to, but think my neighbour has skimped on point 1. I wish I had checked the make of it, but I know it only cost him £8 !
Reply to Electric shower pull switch isolator in the UK Electrical Forum area at ElectriciansForums.net
Hello, I have a customer who is looking to replace their electric shower. There is equipotential bonding connected to the cold feed. I’ve not seen...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
A pull-cord shower switch is located in Zone 2 of a bathroom, including the ceiling base containing the electrical connections. With a little...
Hi, after a bit of advice. Have tried a lot of plumbing and electrical shops but no one seems able to help. I have an Isolator/PSU 230v/12v. It is...
This could possible have been a poll, but really just opening up for suggestions and feedback on where folks think an isolation switch for an...
