New one way rcd protected cu to be installed but the old fuse box (no rcd) main switch does not have space for the R1 wire that is to be connected though the Rn an R2 can be easily connected in the old fuse box, the busbar itself has couple of unused spaces but I can not find any MCBs that will fit in this old fusebox!! now what do I do where do I connect this ?
New cu and old fuse box are just 2cm away from each other. What size wires do i use from old fuse box to ne cu 10mm or 16 mm?
Help will be really appreciated.
