Discuss Electric Vehicles Charge in the Electrical Engineering Chat area at ElectriciansForums.net
Greetings everyone
I work at a company that sells chargers for electric vehicles and I’m working on the electrical projects.
The chargers I work with, are alternating current (AC) and the main mode here is a three-phase installation 220 V, at 7.04 kW with a current of 32 amps.
If the system only had three chargers (Q01, Q02, Q03), the current for each would be 32 amps.
Using a simulator, when adding the fourth charger(Q4), the current goes to 84 amps and I wanted to understand why.
I tried to draw the three-phase circuit to make an equivalence of loads, but I couldn’t get to that value.
Does an electric car behave like a delta or star load?
Greetings everyone
As I am not an expert on three phase car chargers so I will ask what may be some daft questions, how are all theses chargers connected and how is the charger Q04 connected compared to the way the chargers Q01,Q02 & Q03 are connected?
With 3 chargers the system is balanced. When adding the fourth charger it becomes unbalanced. And I want to understand how to calculate the line current, now that a fourth charger has been added and each charger needs 32 amp current.
What does the simulator say when the system has only 2 chargers (eg Q01 nd Q02 only), presenting a different imbalance?
Regarding the car being a star or delta load, I do not see why should this matter unless there is a neutral line present.
If you have 3 phases, why not use 3 phase chargers. Using single phase, the 3 loads could be unbalanced anyway, depending on each vehicles charge state, and whether they were all present at the same time, or not.
You should still wire 1 say as L1-L2-L3, the next as L2-L3-L1 and the third as L3-L1-L2 as otherwise any onboard charger only capable of single phase will pull off L1 on each charge point.
Reply to Electric Vehicles Charge in the Electrical Engineering Chat area at ElectriciansForums.net
Electrical2Go - Green2go Launches for All Your Solar, EV Charging and Renewable Needs Green2Go - for All Your Solar, EV Charging and Renewable...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
Electrical2Go is proud to announce that we now stock eVolo EV charge points. eVolo is the new sustainability brand by Deta Electrical. These EV...
I have a loading arm on a vehicle powered by a hydraulic motor powered by a 12 volt motor. The motor is initiated by proximity switches on the...
Hello, We are converting a former office into 10 self-contained flats with kitchens, showers, heaters all electric, no gas. We have been offered a...
